Speedfight 50LC setup
Discussion in 'Scooter Tuning' started by croozenooze, Mar 1, 2014.
  1. croozenooze
    croozenooze Active Member
    Right, my project is well & truly underway & this is where the stupid questions start.
    I have won a Malossi 70s kit on Ebay, so am looking at rollers, carbs etc.
    I am, hopefully ripping the engine down today to see if there are any "goodies" already fitted.
    I know that it has a TNT Manual choke carb, that I believe are shite, so will probably ditch it & go for a 100 carb & manifold & I'm guessing it's got different rollers in because it doesn't start to roll until it hits 8000 rpm. It's also fitted with a Doppler exhaust, so hoping it won't need too much more.
    I'm looking at something that is fun to ride & fairly quick (if it ever can be :)). So my question is, what would be the best setup for it? Roller weight, clutch springs etc.​
  2. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    Hi
    pretty much impossible to say without trying it but I'm guessing a stiffer corrector spring and maybe lighter rollers. Which Malossi kit is it ?
  3. croozenooze
    Its a 31 9477 MHR Replica cylinder kit according to Malossi's website. I need to do a bit more homework on these scooters, not used to them lol
  4. turbovetto
    tweaked ovetto
    that should work well. dunno if you can just slap one of those on though. might need a bit of casework. Should be a beast though.
  5. croozenooze
    Reading through a lot of the posts on here have helped immensely. I love the internet :)
  6. scubabiker
    tfx block, shumacher racing head, comp cam and roller rockers, flowmaster headers....
  7. croozenooze
    Are we talking cars, or 2 stroke mopeds here? ;) If it's cars, they have too many wheels for my liking, haven't owned one for years. Too much hassle
  8. scubabiker
    thats the spec of a 4 second car... would be cool to stick it in a bike
  9. croozenooze
    Now then.
    Onto jet sizes. I've bought a speedy 100 delorto & could do with a heads up on what size jet for the 70cc set up. I've seen the boxes of different sizes, but need a ball park figure so's i don't buy the wrong box :)
  10. turbovetto
    tweaked ovetto
    My jetting guide:
    look at what's in there before you start. With the same air box -
    upjet 10 /15 points for a move from a 50 to 70 cc motor -
    10 /15 points at least for an exhaust
    another 10 /15 points for a bigger carb -
    then add 5 points for the god of piston rings - try it - and down jet by two's 'till it works.
    If it's an open filter -
    upjet by 30 points at least
    all the points are cumulative. So if you take a standard Ovetto (my scoot) - which started out with a gurtner 12 mm carb with a stock exhaust - jet is about 65
    Kit 70
    Carrerra 16
    28 mm carb
    Foam filter
    You start with a 145 and work down (you end up with about 130/140 depending)
    My maths may be out - but if in doubt, always err on the big side with jets. Saves engines -
    All two stroke engines are liquid- cooled. And the liquid doing the cooling is petrol.
  11. croozenooze
    Cheers TV, I'll get my jet kit ordered :)
  12. James Coates
    James Coates New Member
    2002 peugeot trekker
    I've had no problem with my TNT 19mm manual choke carb it's working a treat
