So my speedfight 3 has a weird issue. It stars fine and will idle for as long as I’ve waited. And then as soon as you touch the gas or a bit after revving it starts flashing the oil light and if the rpms get below 4k it cuts the spark. Then if I cycle the ignition a few times it stops flashing. Any ideas?
Does it do this: The warning light flashes quickly (approximately 6 times per second) : This means that the oil pump is out of order.
