Speedfight 2 rear wheel prob
Discussion in 'The Workshop' started by Line, Jun 10, 2015.
  1. Line
    Line New Member
    Hello guys, my names Daniel and I currently own a speedfight2 50cc 04. I have recently put a stage6 pro rep exhaust, stage6 varator (6g rollers) and belt on it. But now I am having a problem with the rear wheel not turning when revving. When revving I notice the clutch spinning but not the clutch bell? I took the clutch off yesterday afternoon and rubbed the shoes down with sand paper but still no luck. I can spin rear wheel and clutch bell with my hand. Inside the clutch bell were the shoes engage, it's very shiny and slippy? Not too sure what it could be.
  2. scubabiker
    maybe too hard springs? speedfights can be a bit revvy before they engage actually. your bell could maybe be too worn out?
  3. Line
    Line New Member
    Even with the old rollers ( 9g) varator, belt and exhaust ect its still the same, it revs and still nothing :(
  4. scubabiker
    yeah, try changing your clutch springs, as they are what controls the drive to the wheel (sort of anyway) sounds like they are too hard, or that maybe its jammed up. has the bike been stood for a very long time?
  5. Line
    Line New Member
    stood for about a week?
  6. scubabiker
    yeah, have a check of your clutch springs, they are probably too "heavy" to engage with the bell
  7. Line
    Line New Member
    Ok, thinking buying a new bell,clutch and clutch springs. If none if the above is there anything else I could do?
  8. scubabiker
    maybe the belt if its not the clutch. i would change just the clutch springs before buying a whole new clutch.... (because its cheaper!)
  9. Line
    Line New Member
    Today i took all of the inside apart and gave it all a good clean and put it all back together. I then started the bike up and reved it to full power. but while revving to full power the rear wheel spins slow? wheel bearings?
  10. scubabiker
    belt slip or clutch slip
  11. scubabiker
    did the belt get any water/oil on it?
  12. Line
    Line New Member
    Don't think it did, I'll replace the clutch, clutch bell and springs and I'll let you know how it goes
  13. Stevep
    could also have a bell on it thats too big for the clutch, or a clutch that is too small for the bell.
    scubabiker likes this.
  14. Line
    Line New Member
    Right replaced the clutch and clutch bell and when i started it up and pulled throttle it moved! Step in the right direction it seems. But now theirs a weird clicking/clanking sound from inside the end of the case were the clutch is ect. other then that seems to move ok. Was thinking a bearing ? :(
  15. Stevep
    sounds like summat loose
  16. scubabiker
    sounds like a broken sort of sound, best take the case off and check before you wreck something, probably clutch/vario nut loose...
  17. Line
    Line New Member
    I definitely made sure everything was tighten up. I was thinking the bearing on the
    torque driver?
  18. scubabiker
    best to make sure, ive seen it a hundred times, nut comes loose/is over tightened and it fucks the transmission/crank etc...
  19. Stevep
    And ends up coming through the belt case as I found on one scoot!
    This is exactly what happened to my current Katana.
