Speedfight 2 indicator problem
Discussion in 'The Workshop' started by Nickgilera, Jan 16, 2016.
  1. Nickgilera
    Nickgilera New Member
    Hi, I have a speedfight 2 2001 100cc scooter.
    The indicators were working a few days ago except I knew that there was a loose connection which I had to tap and it would be fine.
    Now the indicators don't work at all, even the light on the dash doesn't come up. I have stripped the indicators and cleaned the connections and secured the cables. I don't know what it could be?
    The horn, high beam/low beam and all electrics work Except the indicators. Any ideas?
    Thank you
  2. scubabiker
    try either new indicator relay, or possibly the connection in the switch itself, people dont realise, but you need to lubricate/service switches, without a bit of oil (all in one, WD40 etc) they stop working very quickly.
  3. Nickgilera
    Hi scubabiker, thanks for the advice, turns out it was the indicator relay, found one of the wires completely detached from it. Thanks again
