Hello, Ive got a 02 plate speedy 2, when i first got it it would shot off to 30 then bog out then when it gets to 40 and revs more. After awhile it went and ran fine. Now i had to buy a new exhaust, i got a Giannelli Extra and i use to have a Doppler S3R, both have had the restrictor taken out. The ped has started boggin when i hit 30 then builds up revs after 40. The has and "sport" reeds fitted and upjeted 10% I thought it was the rollers, but it bogged out on the doppler then after awhile it went. I cant think what it could be? many thanks
Have you changed the rollers at all since you've had it? Did you check your plug to see how accurate the jetting is?
I've put lighter rollers in, runs fine now. It dont go as fast as it did but prob just the pipe. Its running rich atm, i only had a 68 or a 76 so i would rather run rich then lean, but orded jets today.
