got it fixed it was the regulater, i got a used 1 for 5 pounds in a BIKE SHOP haha, well thanks for help GUNS and others!! happy days
oh yea the bulbs on my mian lights were the problem, they were 65/55 W and mine were ment to be 35/35 W lol im well happy now
hey guns just 1 last slight problem, when im driving and i use the breaks, the front main beam dims down JUST A LITTLE BIT, is this fixable or is it normal? the battery is 13.88v will it just need couple more hours charge mabye to even the power about? and 1 last thing what volt should my battery be as i can now charge and track what volts it at!
how tight should a spark plug be? should it be tightend as hard as it can go or should it just be tightend enough like a couple of turns with the wrench?
you do that, and you will strip the thread, and be in big trouble, the torque is hand tight and just nipped up......... tight but don't apply any strength, at a guess I would estimate about 12Nm, but not many have a torque wrench that low, so it's by feel.
you can't loosen it, undo it fully and re-tighten. Maybe it's okay, but you were lucky, with a bit of leverage you can strip a spark plug thread with one hand, especially if the head is alloy.
yea i took it right off to c how it was, this is the 8 pound 1, and theres oil around the thread but the main part looks untouched
not only are you using current with the brake light, if you are braking, you have shut off the throttle, the clutch has disengaged, and the revs have dipped to a rpm where the alternator isn't spitting out much current.
nice one mate nothing makes me happyer than seeing someone fix the problemn them selves garages are a rip off. bet uv learnt a thing or two along the way aswell bud
just a quick question for you guys (people who know about speedfight 2's ) was just wondering if there is any way i can change the oil light bulb on the dash as i think its blown because it dont light up when starting the bike ive changed the 2 stroke sender and i know that works because it was tested before i bought it so it carnt really be anything else so yeh if any 1 knows how to change it,, it would be most helpfull thanks
