speedfight 2 100 brake caliper issues
Discussion in 'The Workshop' started by xXRipleyXX, Apr 12, 2020.
  1. xXRipleyXX
    xXRipleyXX New Member
    the speedfight im trying to piece together (got for £100) im having issues with finding a caliper,
    its not the AJP caliper and the rear caliper is a slide caliper.
    does anyone know or tried any other caliper conversion?
    would newer speedfight calipers fit ect?
    any help is much appreciated.
    speedfight 2 is 2013 model, 100cc
  2. Stevep
    You might find it easier to replace the pistons and seals instead.
    Very rarely does a caliper body go bad, normally it's just the piston gets severely pitted and the seals leak.
    What problems are you having with it?
  3. xXRipleyXX
    the Haynes manual states there is no official overhaul kit for the caliper, i used heat to finally get the pistons out, pistons are not reusable, so I've just measured for a piston kit and seals to fit. time will tell once i bleed them. seems to be a very hard caliper to get hold of :/
