speedfight 100 front brake disk/hub
Discussion in 'The Workshop' started by simon1984tech, Jun 29, 2011.
  1. simon1984tech
    simon1984tech Member
    speedfight 100
    hi got a problem not to sure how bad, i took my wheels off to spray them the other day, when fitting them back on i over tightened one of the nuts snapping the thread on the front wheel hub, i went and bought another which also had the disk on it i fitted it straight on but now when the wheel turns i can hear it rubbing the brake pad slightly only in on spot, does this mean the disk has a slight kink in it like a bit bent? could i have put the hub on wrong? it can't be the pads as it only rubs at one point on the disk any help would be great
  2. simon1984tech
    speedfight 100
    any ideas anybody??? came off today front wheel skidded and went under me no serious injury just twisted my knee pretty bad sore as F**K !
  3. tErr0
    It could be a warped disk yeah... If you have another disk just swap them over and see if it still does it.
  4. simon1984tech
    speedfight 100
    got another disk just cant get a tork bit the right size, should be able to sort it tomorrow though, cheers for the reply
