speedfight 1 immobiliser?
Discussion in 'The Workshop' started by suzuki ay screamer, Sep 6, 2009.
  1. suzuki ay screamer
    suzuki ay screamer New Member
    my mate has just brought a peugeot speedfight 1999 ( yeah i know speedshite and all tht other crap) but the only problem is the immobiliser wont let him start the engine is there any way of disconnecting the immobiliser or bypassing, he has all the keys for it and has tried reprogramming key to no avail help needed please :D
  2. wobbly_trials
    if i remember rightly its part of the CDI unit, the best way to bypass it is to get an aftermarket CDI
    OR
    Convert the stator and CDI to that of an italian scoot like the yam or the piaggio system (i know yam are jap but the engines are italian)
  3. MiNoR cOnFuSiOn
    the aftermarket cdi's are probably the best way round it... you can program the key but if the method your using is the manufactor method and its not working chances are the key/cdi is blanked from lack of power/static/shock/water (depending on what has faild)
    chances are it was a lost key, it was replaced and didnt get programmed by the last owner?
    need the master key to program any new key so it may be the problem, your maybe trying to program it with a "read" key rather than a "write" key
  4. monty9120
    monty9120 Active Member
    Vespa gts300
    get a malossi unimmobilised cdi. will plug in and bypass the whole ignition :grin:
