Speed fight 2
Discussion in 'Scooter Tuning' started by jessegriffiths12, Dec 18, 2013.
  1. jessegriffiths12
    jessegriffiths12 Member
    Bought a gianelli exhaust for my standard 50 speedfight it did about 55 now I've put a 70cc kit on it and a technigas silent sport exhaust on and it won't do over 50:(?? Any help
  2. PDBV
    PDBV Member
    Have you up jetted? Any other symptoms ?
  3. bam bam
    bam bam New Member
    Assuming everything was fitted correctly, Most likely need carb and transmission set up right, I'm going through it myself and it's a pain, especially while running in
  4. jessegriffiths12
    Haven't done anything except that what jet size should I use
  5. PDBV
    PDBV Member
    I have no idea off the top of my head but im sure you need to upjet for a 70s kit maybe have a look in the tuning section
  6. jessegriffiths12
  7. Nathanael
    Nathanael Active Member
    and check for aa restrictor in the new exhaust :)
  8. jessegriffiths12
    Where would that be mate? I think the one by the top by the bolts has been taken out
  9. Merlin
    Merlin Old School Biker
    2007 TKR WRC 50
    Your mixture is running weaker at the top end due to the sports exhaust. Take the main jet out of the carb, read the number stamped on it, add 4 to that number and that's the minimum jet size you need to correct the mixture.
  10. jessegriffiths12
    Ok will it need to go up any more because I have a k&n style air filter
  11. Merlin
    2007 TKR WRC 50
    Yeah, that won't help either as that will also weaken the mixture. The air flow has increased inside the engine and you need to increase the fuel flow to compensate.
  12. jessegriffiths12
  13. Merlin
    2007 TKR WRC 50
    You need the set that goes above 72. Pedstop, Pedparts or similar will stock the larger size range kit.
  14. jessegriffiths12
    Ok what should the lowest be?
  15. jessegriffiths12
  16. Merlin
    2007 TKR WRC 50
  17. jessegriffiths12
    It's the standard carb
  18. jessegriffiths12
    I think gurtner
  19. Merlin
    2007 TKR WRC 50
    The standard Gurtner carb takes 6mm jets.
  20. jessegriffiths12
    Could anyone send me a link to a gear up kit I should use? Thanks
