spark plugs and rollers
Discussion in 'Maxiscooter Tuning' started by shiny red, Jan 19, 2008.
  1. shiny red
    shiny red New Member
    got a new spark plug from pm tuning yesterday aNGK BR9EIX did have aNGK BR7ES in ,its made quite a differance ,start off from cold it used to bog down till you gave it full throttle ,if you let it warm up first it was even worse,but now whoosh power striaght away :w00t: they sent me the wrong rollers though 13.5 grms instead of 12.5 grms i have got 10 grms in there at the mo is it worth giving them a try ??? :nerd:
  2. monty9120
    monty9120 Active Member
    Vespa gts300
    10 grams fuck me i didnt want to go lower then 12.5 on my 172 otherwise i would have killed myself :w00t:
  3. shiny red
    been in there since i got it ,you got that stuff yet monty :D
  4. MiNoR cOnFuSiOn
    give em a try.. if no good use 3 of each alternated.
    supprised it even ran with the 7es.. do me a fav an tell me what the carbs setup too as i recon you have a couple horses hiding around your engine..
  5. capri dave
    capri dave Active Member
    im useing a different plug in mine too shiney ;)
    ive swopped my BR9ES for a BR9EG...and its running nicer at low to mid range revs...still about the same top end though!!
    oh and just incase your not familiar with the EG plug its a fine wire nickel electrode ;)
  6. shiny red
    do not know how the carb is set up when i do the rollers i have a look minor ,dave when pm sent me the stuff there was a flyer in there for their pm71c exhaust you seen it ? :D
  7. lol
    lol New Member
    i have got 12 gram rollers and its still a hand full to keep the front wheel down :rofl:
  8. numanoid1704
    numanoid1704 New Member
  9. SMF_12
    SMF_12 New Member
    I managed to track you a set of rollers fella. 12.5gram i believe, you wanting them?
  10. shiny red
    thats the ones numanoid ;) i will try these today and let you know smf 12 cheers :beer:
  11. MiNoR cOnFuSiOn
    thought it was a typo... send the shit iridium plug back.. its not an rs
    worthles in these m8.. stick to a br9es as they last more than 10 mins and are only 3 quid.. why the hell are pm sending them out now :confused:
  12. numanoid1704
    runner 125 fx
    so not worth buying? ,will see you weds shiny about 1pm. come hell or high water!! lol, cheers
  13. shiny red
    put some vids in vids section with the 13.5 rollers in and its so slow? right the set up i got is main jet 108 needle d30 circlip is set second up from the bottom the jet next to where the needle goes into is a45 the one in the far corner is a 60 the brass thing that the float opens is a 200 this is all on a PHBL25BD I have red clutch springs and the big spring is yellow .its got a athena speedmaster variator.malossi 172 on a 180 case with a scropion pipe? i hope this makes sense engines are not my strong point so bear with me?gonna do another vid cause i have put the fucked tens back in and it flies but its raining at the mo when it stops look out ? :D any advice on set up i would be most gratefull :beer:
  14. Daniel172
    Daniel172 Member
    I think the red clutch springs could be too hard. I've heard of quite a few people using the blue one's, so it could be worth giving some a try ;)
    On the carb side mine is pretty much the same except it has a 102 jet in and the needle clip is one from top, My rollers are 13.5 and the bike seems to pull really well although I’m changing to 13.0g soon as I want it abit more revvy :cool:
  15. MiNoR cOnFuSiOn
    right,m not sure how those variators act so thats probably why the rollers are light.. sounds a little rich and the needle needs dropping down me thinks.. rest should be fine. but 108 is a tad big for a wc.. grab the plug an have a look. not definitive but tells you roughly how its been running
  16. shiny red
    will do minor and thanks, cheers to you to dan 172
  17. shiny red
    put the 8 grm ones in now pretty much the same as 10 grms :wtf:
  18. MiNoR cOnFuSiOn
    id be trying out a stock variator with 12.5's... ramps sound a little steep from that
  19. shiny red
    ok just a standard one nothing with malossi or polini in the title then :w00t:
