spark plug keeps breaking
Discussion in 'The Workshop' started by Chubbler, Jan 3, 2012.
  1. Chubbler
    Chubbler New Member
    my runner keeps nakering the plug up it got a geanelli exhaust and mallosi air filter in the air box the plug goes black and then nakers up it has standard jets inside and smokes quite alot
  2. FLENG2008
    FLENG2008 Member
    04 vx 125
    Dry and wet fouling
    Fouling, either dry (top - matt black, sooty) or wet (bottom - gloss black, sticky), Can be caused by many different conditions. Carbon deposits build up when the plug fails to fire correctly and burn them off. Air/fuel mixture too rich, choke stuck on, electrical problem, extended periods of low speed driving, plug heat range too cold. All should be investigated
  3. Chubbler
    Chubbler New Member
    ok thanks it wet fouls an really smokes when you rev it high do you think its the jet and do you think i should go up or down jet
  4. Jonnymarrw00t
    Piaggio Zip 05 plate
    Up from standard. to about 65.
