Spares required
Discussion in 'The Workshop' started by Nathan Woodhall, Oct 30, 2016.
  1. Nathan Woodhall
    Nathan Woodhall New Member
    Hi guys does anyone know where you can get spares for a HMC VOGUE I need a rear light lens and lower side panel trim along with the light unit below thanks Nathan
  2. Stevep
    Same as a WK Bikes VS50
  3. Nathan Woodhall
    Thanks fella appreciated, I presume it uses the QMB 139 Engine also ????
  4. Stevep
    I would presume so, but don't quote me on that
  5. Nathan Woodhall
    Does anyone know what engine this bike uses ?
    After reading other posts I'm gonna get a derestricted CDI then remove the shim on the variator and check the carb for a restrictor......
    Just need around 40mph to keep with traffic at the moment it is 33mph on the flat and 25 uphill .....
  6. Tamiyacowboy
    Tamiyacowboy Pippa's Owner
    Piaggio Skipper
    GY6 or otherwise known as the 139QMB -139QMA
    kinda hard to tell as CMPO dont have the Vouge listed under HMC parts just the HMC lightning 125cc ( possible HMC uses the same motor from the vogue in the lightning ) so maybe check out the lightning model and see if that motors sidecasing looks like yours ( kickstart side) usually find they carry parts over saving on build costs ( why use new toolings when you already have old ones)
    Nathan Woodhall likes this.
  7. Nathan Woodhall
    Thanks for that info I'll check it out ....appreciated
    Sent from my CUBOT_NOTE_S using Tapatalk
  8. Nathan Woodhall
    Thanks mate
  9. Tamiyacowboy
    Piaggio Skipper
    aye no worries, shame they didnt go with a leader style motor like the vespa's , being that the vogue is near on a vepsa like machine or close enough to
  10. Nathan Woodhall
    Very true mate , once I find out what engine it is I'll deresrict it properly just enough to get 40mph allowing me to keep up with the traffic
  11. Nathan Woodhall
    Just checked underneath and yep its a QMB 139 so cheers for the info ....I'm going to do the work myself as its pretty simple and straight forward
    Deffo needs a de restricted cdi as it flutters when a certain rpm is reached
  12. Nathan Woodhall
    What roller weight would you recommend ? Some say 5.5 some say 7.5
  13. Nathan Woodhall
    Also AC OR DC CDI UNIT ???
  14. Tamiyacowboy
    Piaggio Skipper
    put 6g rollers in as a base line ( middle the road of the 5.5 -7.5 )
    If yours is working try disconnecting your battery, if your engine dies you have a DC CDI system. With an AC CDI it will continue to run.
    Most CDI's with large bodies tend to be DC / CDI's with a body like a small matchbox tend to be AC
    You can also tell by the wiring, if you have 3 or 4 wires going into the four plug that doesn't make much difference, but if you have 2 wires going into the 2 plug this is likely to be a DC CDI / 1 wire going into the 2 plug means it is likely to be an AC CDI.
    Beware there are anomalies to these rules but most CDI's follow these rules
  15. Nathan Woodhall
    Cheers mate ....looked by the battery and took all the seat housing out today and no CDI to be found ...any ideas where it might be ?? Been told I need a AC for this model so we shall see if I ever find it lol
  16. Nathan Woodhall
    Result ..managed to match the panels to a WK bikes VS50 and just ordered the side panel and rear light etc for £70 not bad as the bike cost me £375 which for a 15 plate is cheap
  17. Nathan Woodhall
    sent via Android using tapatalk
  18. Nathan Woodhall
    Uses QMB139
    No carb restriction
    Unsure on variator shim (awaiting locking kit to remove)
    Cdi unit is restricted
  19. Nathan Woodhall
    As shown lower side panel broke and rear light lens and numberplate light broken off
  20. Nathan Woodhall
    On order
    Plastics and rear light
    NGK C7HSA Spark Plug
    Derestricted CDi
    New rollers 5.5g and 6g
    Fuel filter
    Top Box
    600k Xenon kit
