Fitted oil pipe. Bled it. The bike runs smoother an you can see the smoke coming out the pipe <3 But! Itll idle perfect an when i rev the bike on stand itll spin the wheel but not very fast. I sit on it an rev itll only do about 15mph but you can feel the bike revving? :/ cleaned my variator ect as they were coverd in 2 stroke. Could it be the belt slipping becaus its had 2 stroke on it?
quiet possibly, if the bikes revving out but not going anywhere then somthings a miss. if the roller weights are correct from before then somthings slipping either belt or clutch pads
Rollers are new an were fitted before this happend. So i need a new belt? Is there a way to clean mine? as its nerly new ahaha Could it be to do with jetting? I have a 64 jet (fitting 60-62 soon) with a doppler pipe could it be needing new piston/rings? Sorry for the questions hahah
why are you downjettting and fitting a sports pipe? i have no idea whether your issue is jetting, but if its revving out and not moving i wouldnt have thought its jetting. you need something to remove any grease/oil from the pulleys etc. i dont know if itl work but id imagine white spirit would help. as for removing oil from the belt i havent a clue. once you have it moving and going then you can sort the jetting
Nah ive put a bigger jet in as its running quite rich an yeah i get what you mean. Ive just cleaned the pullys ect just need a new belt now cheers
