soon as you touch the throttle it dies!!!!
Discussion in 'The Workshop' started by 2many2strokes, Oct 24, 2012.
  1. 2many2strokes
    zzr1400
    hi
    got a unmodified diesis 100 it kept cutting out like it was starved of fuel. took the carb apart and the jets were blocked. cleaned it and put it back on the bike. it idles fine but as soon as you touch throttle its cuts out, the plug is dripping wet. ive tried adjusting the airscrew and even when its fully wound in the plug is soaked and it dies. please help!!!
    thanks
  2. JamesC
    JamesC Member
    Speedfight 100
    Fully wound in is max rich. Get a new plug.
  3. A-LY
    A-LY Active Member
    differant size jets
    needle clip position
  4. 2many2strokes
    zzr1400
    ok thanks with mikuni carbs its the other way round i will give that a go. also the jets and needle position are all correct according to the manual
  5. JamesC
    JamesC Member
    Speedfight 100
    If the carb is well used and worn try lowering the needle (rase the circlip) making it a tuch leaner. To check the carb needle jet, romove the throttle slide look down at the needle jet with a torch. It should be a perfect circle. When they get worn they go a bit oval causing the bike to run richer between 1/4 and 3/4 throttle.
  6. A-LY
    A-LY Active Member
    dont put full faith in a manual, my old suzuki one had me going straight over a berm into a bush flat out because i jetted it exactly to the book
  7. 2many2strokes
    zzr1400
    finally got the little shit running, your right the manual is just a load of crap no help lol thanks for the info guys!!!
