someone please help =(
Discussion in 'The Workshop' started by harrison, Jun 15, 2007.
  1. harrison
    harrison New Member
    i love my aerox. its looks and that but it goes 35mph as some of you are aware. i really want to be able to get this going good. does anybody have a clue what i could do. its meant to be derestriced. do you think it could be my viper exhaust, rollers what else? what size rollers should i buy and what else could i get or do to make it run. If i took this to a good garage would they be able to fix my problem??
    if you need to no certain thigns ask me and ill try and find out about it.
  2. Sw1fT
    Sw1fT Active Member
    200SX S13
    take the exahaust off and see if the restriction is in there, then have a look at the variator, as it might not be derestricted afterall.
    it also might not have been jetted properly, so if the restricting collar isnt in the exhaust check the jet because it might be too lean. also if the restricting collar is in the exhaust then still check the jet because someone might have upjetted without derestricting the exhaust, running rich.
    you will sort this problem, theres no need to sell up and move on imo
  3. tinribs
    tinribs New Member
  4. harrison
    harrison New Member
    im going to take the exhaust off i think the restrictor is out of it and the extra washer has been taken off by the rollers. not sure what you call it. im gonna go take a look in a while tohugh
    and i dont know what jets are :p i dont know much about scooters
  5. Sw1fT
    Sw1fT Active Member
    200SX S13
    well do you know what the carburettor is? and where it is?
    basically, get a cup and put it under the hose coming from the bottom of the carb, and turn the screw next to the hose, that will drain the fuel out.
    most people dont like disconnecting all the hoses, so if you just undo the manifold hose clip and take the airbox off, then turn the carb upside down and theres 2 screws, undo them and take the float bowl off, then u will see 3 brass fittings, undo the bigger one with a flat screwdriver and thats the jet, see what number is on it and post it on here, someone can help u after that because i dont know the standard jet.
  6. harrison
    harrison New Member
    hhmmm this all sounds hard to me :msn1: do you think it is best if i took it to a garage. if i said to them its meant to be de restricted and running at 35mph can you fix this for me do you think they would be able to find the problem?
  7. MiNoR cOnFuSiOn
    im guessing its not got the correct weight rollers for the pipe.
  8. harrison
    harrison New Member
    would you be able to advise me on what weight rollers aproximalty i should be looknig to buy?
  9. MiNoR cOnFuSiOn
    nope, read thre guide and figure it out. i havent ridden your bike
  10. Sw1fT
    Sw1fT Active Member
    200SX S13
    i swear somewhere you said its had 5.5s fitted? try going down 0.5 grams, even doing that might not help if the jetting is out
  11. harrison
    harrison New Member
    well it says when it had the exhaust fitted it had 5.5g rollers fitted. i have weighed different rollers i got and there 2g each.
  12. Sw1fT
    Sw1fT Active Member
    200SX S13
    even though theyre probably stupidly light, try mixing 3 2gs and 3 5.5 grams
  13. harrison
    harrison New Member
    i need to get a variator locknig tool or is there an easy way to get to them without one?
  14. pricey
    pricey Member
    From your wording it sounds like you're saying the rollers in there are 2g, that is probably why then, they are way too light, get some heavier ones about 4-5g and see what that does. Start with the easy stuff, like rollers and belt, then move onto jets if that doesnt do anything. Take the tranny case off and have a gander, make sure your belt isnt worn too much and everything looks sound, then get some heavier rollers from www.beedspeed.co.uk or some other shop, a selection of weights will be better, then go to your local bike shop and get them to fit them, then see if anything is improved...
    Then come back to us.
  15. harrison
    harrison New Member
    it says there is 5.5g fitted already
  16. -Grant-
    -Grant- New Member
    a bike can actually talk didnt know that :bird:
    i might ask my bike what rollers it has in it
  17. harrison
    harrison New Member
    i didnt say my bike says i didnt actually be specific on what told me it had 5.5g rollers in it :bird:
  18. aerox_soldier
    aerox_soldier New Member
    did you check for the restrictor in the exhaust like tin ribs??
    take it your local bike shop and get a service onit if you want to avoid doing it your self as you clearly dont have a clue
  19. harrison
    harrison New Member
    your right i dont have a clue but my exhaust doesnt seem to have a restrictor in it. im not sure what is actually restricing this bike. no variator washer or exhaust restricot :msn1:
  20. Vap0ur
    Vap0ur New Member
    go and get a service !!!!!!
