03 aerox engine cases 2 sets of aerox wheel good tyres aerox frame aerox forks and shock good condition aerox brake caliper,hose and master cylinder front and rear good pads piaggio zip engine cases 1 stud snapped but will drill out and rethread if wanted set of black typhoon wheels needs rear tyre but front is good vgc no scratches standerd piaggio variator and aerox variator aerox belt Dr 7occ kit runs ok but not much compression needs new rings bore is ok comes with polini cylinder head piaggio zip belt good condition standerd piaggio zip crank will fit nrg n typh polini evo 2 cylinder some light scratces on bore ran fine but needs piston/ring as i dropped the piston and it borke brand new hebo inlet manifold will fit 21/ up to 28 mm carbs 24mm mikuni carb some other stuff if i remba lol post what you want and a price and i will say yes/no derestricted inlet manifold for aerox up to 21 mm carb piaggio lc standerd 50cc cylinder ,head , piston and rings done 796 miles vgc will fit nrg lc zip sp new sr with piaggio engine gilera runner and othes
aerox engine cases and inlet mani fold sold polini evo2 sold if u want anythin else that aint on the list pm me what u want and i will have a look in my garage to see if i have it mainly piaggio /yamaha stuff
aerox panels need spraying but i will sand them down and primer them and spray them a colour of your choice if wanted offers.
