Smell rubber burning when im riding
Discussion in 'General Scooter Discussion' started by CA Zip tuning, May 10, 2012.
  1. CA Zip tuning
    CA Zip tuning Member
    Hi guys well as the title says really, when im riding my bike I can smell rubber when im buring, do any of you know why this might be ? cheers
  2. Edgar
    Edgar Active Member
    probably something in transmission , check if you fitted the front pulley straight with all washers inside
  3. CA Zip tuning
    I have never touched the transmission the only time its been touched was 7 months ago when my rollers got put in
  4. CA Zip tuning
    and that was by a scooter mechanic
  5. Edgar
    Edgar Active Member
    oh not sure then , check your oil pump belt( behind the variator ) might of went
  6. CA Zip tuning
    wheres that ?
  7. J4CK
    J4CK Member
    Piaggio NRG 172
    Behind the variator, take the nut off your crank take the front pulley off and variator and you should see it :)
