Slow acceleration on my NRG
Discussion in 'The Workshop' started by Lukash, May 19, 2008.
  1. Lukash
    Lukash Member
    SR125
    Hi, im new to scootering and just picked up my first bike. Got a NRG extreme air cooled with 70cc kit, doppler pipe and a malossi carb and reeds.
    I got it off a guy who bought it as parts and completely rebuilt it. SO that means everything is pretty much new but needs running in.
    Its pretty slow atm but have managed to get up to 50mph on downhill.
    Only problem im having is that its taking ages to get up to speed, could this be because its not run-in yet or would that not be related?
    cheers, Lukash.
  2. foster
    foster New Member
    if the cylinder still needs running in you dont want to be going 50 on it, you should be keeping revs low and going around 30 for the first 100-500 miles
  3. Lukash
    Lukash Member
    SR125
    Thats fair enough, it was pretty steep hill so it was gravity doing most of the work.
    Main thing i wanna know is if acceleration will pick up once the bike is run-in?
  4. pow
    pow New Member
    It may free up slightly, but nothing drastic.
    Running a bike in allows all the engine components to gradually come together to make evrything smooth
  5. capri dave
    capri dave Active Member
    The parts have probably been bolted on without setting up,
    jetting, idle mixture screw, rollers and clutch springs need changing/adjusting ;)
  6. alexsr70
    alexsr70 New Member
    you sure the doppler isnt restricted?
  7. Lukash
    Lukash Member
    SR125
    Im a complete noob to motoring so i dont know how to fix/check any of these :emb:
    Any online guides that might help me out? or any advice on what i should do?
    I would just un-do some screws and take a look but i dont wanna fuck my bike up
  8. Lukash
    Lukash Member
    SR125
    Update: I spoke to the previous owner today and he said that its not been up-jetted and has a stock air-filter. He said he thinks it should be fine as it is.
    Do you guys recommend up-jetting or changing the air-filter considering it has a 19mm carb?
    thanks, Lukash
  9. Aerox-lad
    Aerox-lad New Member
    you are also gonna need primary gear up and secondary if you want it. or else you wont see much past 60
  10. alex_1966
    alex_1966 New Member
    what is it with you and gear up kits lol
  11. alexsr70
    alexsr70 New Member
    he dont have one, and dont no what is going so ignore him lol
    it will definately need jetting, not necessarily UPjetting but will need to be setup.
    with the way the previous owner refers to the jetting as not bein a problem then i would suggest that it be setup. this is why your bike is underperforming rollers, jetting and clutch springs may need to be changed
  12. Lukash
    Lukash Member
    SR125
    ah right thanks, I think i just need to find someone who knows more about tuning to take a look at it and tell me what needs to be done
