my yamaha slider is smoking abit and i was woundering if anybody could help me, if they not what the problem is.. thanx
slider is a minarelli air cooled, parts are common as muck. wouldnt worry about a bit of smoke, it means the pump is working what oil do you use?
it could be just your oil pump is too far advanced, you can adjust this with the cable that goes into the front of the left crankcase (where the variator is) the cable should have a slight bit of slack then open when the throttle does.
just bought a slider 2003 with 2700 miles :rofl: non runner atm needs gasket and bolt on the head and battery on the bike is new polini bearings piston and rings malossi reeds and cage custom technigas exhaust spare parts with bike included malossi clutch bnib polini 70 kit brand new seat footpegs indis
