Skipper 172, Malossi 25mm carb problem..
Discussion in 'Maxiscooter Tuning' started by JScoot, Jul 26, 2012.
  1. JScoot
    JScoot New Member
    Some time ago I started similar thread about original vm20 carb... http://www.scootershack.co.uk/threads/skipper-172-vm20-carb-problem.26169/
    Well it was not ok after all, it was running rich from off-idle to 1/8...1/4 throttle, so I was thinking that malossi 172 kit would work better with malossi 25mm carb. (Malossi 172cc kit (AC kit with malossi head), stock airbox, stock "runner" exhaust )
    It did not,.. exact same off-idle to 1/4 throttle 4-stroking/pig rich! Up from 1/4 it is "ok" so main jet is fine. I have checked all external thing that could affect this richness but no results :(
    Why is this, I have not heard that most people had need to "tune" (this carb/cylinderkit) with idle jet or slide, or different needle??
  2. ramo
    ramo GoldMember
    I had this exact setup pretty much i didnt need to change anything only the main jet.
  3. creamsodauk
    creamsodauk Ped Ped!!
    Runner 125 SP
    i run a 25mm dell carb, i was told it was set up to run fine with stock airfilter but required most jests changing when i whent over to an open filter,
    have you checked what jets are fitted in yours, and wether they are clear and not blocked
  4. JScoot
    JScoot New Member
    This is so weird, couple of days ago I changes original idle jet (45) to 38 and it did not help much. Idle is so rich that I can turn in idle mixture screw all the way (yes, idle mixture, not idle air screw) and then idle revs start to rise. If I open "start enrichment" when engine idles, engine dies. Engine also idles well just after start without enrichment.
    I even lowered the needle to lowest position (original setting was 1 higher..) not much difference.
    I just checked reed block, it is solid metal with rubber coating/sealing and it is tight.. just to be sure I changed original reeds but did not test run it yet (idling was about the same..)
  5. 172NRG ASH
    172NRG ASH build it, ride it, break it, start it again......
    nrg172cc,,runner70cc
    what about your pin in there carb were is tht set ?
  6. JScoot
    JScoot New Member
    Sorry, language barrier, "pin in there carb"? (you mean carb slide needle->above post)
    Here is little demonstration of the problem (just using very little throttle..) Running sound "heavy"..
  7. JScoot
    JScoot New Member
    Now this starts to clear up... as I figured it was not mainjet, and testing showed that it was not slide needle height, nor choke and I tried lot leaner and little leaner pilot jet and it did not fix it.. And even reeds were ok. And no air leaks.
    What was left other that malossi 172 kit was "broke".. just carb slide. Malossi 25mm carb somehow uses richest slide available (30) so my last try was desperate and could have ruined the slide. I filed it leaner, original cut height was 3.0mm (somehow slide number 30 fits to that measurement ;) ) So I cut it to about 4.5mm and it did a lot!! Now it starts to be close..just little roughness so I'll file it little more and then hopefully I can enjoy driving it :)
  8. bashyy21
    bashyy21 Beaut!
    dounds like u have a knocking noise coming from the engine might just be then vid ?
    any air leaks maybe its getting air from some where giving it more air to burn the fuel so its raising the revs i could be wrong just an idea
  9. italjohn
    italjohn Member
    I have struggle with exactly the same problems on my Runner 172.
    I have a slide 60 on mine, still not good enough.
  10. JScoot
    JScoot New Member
    Nice to hear that I'm not alone with this issue :) Well, I was too happy to soon.. I filed the slide even more (to about "60") and it did not improve any more.. so issue is not resolved yet and there is not much to do.
    I wonder why malossi cylinder kit behaves like this.. it is not even high end in terms of power.
    Italjohn, what kind of tricks you have tried with this problem?
  11. MiNoR cOnFuSiOn
    pilot jet is too small.... the needle is incorrect.. change to a d25 needle, aq282 atomiser, clean the carb and start again... DO NOT FILE SLIDES. you need a 30 or 40 in there
  12. JScoot
    JScoot New Member
    There is only aq260-270 available?? 282 atomiser would make it even fatter in up to 1/4 throttle.. (stock is 266, if I remember right..)
  13. MiNoR cOnFuSiOn
    tbh most of the carbs nocking about are pretty close (unless youve ripped this off a crosser) so needle, jet pilot should be enough... its an auto. its only really "loaded" full throttle. leave the atomiser, grab the correct needle (as fitted to the "malossi" version) if your having this much trouble setting up a 25mm then theres one of 2 things wrong, the carb is junked, or you need to take it to a dyno as your reading the thing wrong.
  14. MiNoR cOnFuSiOn
