Sinnis Matrix !! (starts but wont rev up when damp weather)
Discussion in 'The Workshop' started by Jog_RR_madhead, Sep 18, 2017.
  1. Jog_RR_madhead
    Jog_RR_madhead Trainee bike mechanic in need of assistance
    Direct bikes Lynx
    My bike is just recently doing my head in, on a dry day it works fine but during a damp or rainy day it starts and ticks over but refuses to rev up, just cuts out instead.
    I borrowed it to a friend and he put the high octane fuel in without my knowledge, when he brought it back it was playing up.
    Stripping the carb did no good so I bought a new one and it worked fine until the evening when it happened again, at that point he told me about the fuel.
    I completely cleaned out the tank and the carb etc and refilled with normal unleaded and it worked fine until we had a downpour earlier, despite it being under cover.
    It starts but does the same, cuts out when I open the throttle.
    Getting desperate now, hope someone can help
    Thanks
  2. MARSH
    Spray wd40 all over electrics/plug, any wiring you can see.
  3. Mark Emerson Trentham
    Check your plastics are fitting together properly,as water may be/being guided to hit certain spots.
  4. Stevep
    The higher octane fuel wouldn't cause that problem I don't think.
    Does it have an open filter on it?
    Is there a good seal at the airbox if standard?
    Is the airbox itself sealed properly?
  5. scubabiker
    What steve said
  6. Jog_RR_madhead
    Direct bikes Lynx
    Thanks for the replies
    I have ordered a new loom as under closer inspection it does seem as though someone has messed with it, the plugs to cdi were iffy also
    cheers
  7. Jog_RR_madhead
    Direct bikes Lynx
    Thanks, think it was to do more with rain than fuel but seemed a coincidence, especially as the fuel we drained had sediment in it.
    To answer your questions:
    closed filter
    good seal
    generic but ok
    thanks again
