side stand jog rr
Discussion in 'The Workshop' started by JogRguy, Mar 20, 2009.
  1. JogRguy
    JogRguy New Member
    i got a side stand for my jog and i have no idea where it goes does anyone else have one or does anyone have a clue where it goes ??
  2. bait
    bait Active Member
    have you looked at the bottom of the bike usualy some wer around the belly pan
  3. JogRguy
    JogRguy New Member
    i looked there but i think the radiator might be in the way
    and whats the best way the fix panels that have snapped off ??? im using duck tape lol
  4. bait
    bait Active Member
    tbh im cant really say with out pics but if its a bit snapped off and you have both bits then get a fibreglass kit from local car shop or halfords
    should do the trick
  5. Blue dwarf
    Blue dwarf New Member
    I cant find anywhere that lists a side stand for a Jog RR (liquid cooled) and this is probably because no-one makes them :confused:arc:
    Buzetti and a few others make them for the Jog R (air cooled) also MBK Mach-G so be carefull when buying.
    The Jog RR radiator is low slung and in front of the engine EXACTLY where the air cooled side stand should mount so the morale is an air cooled one will not fit.
    Oh we`ve fitted an aerox side stand to a Jog-RR before by welding it to the frame but this is not exactly bolt on and if anyone has got a part number and supplier for a side stand for a Jog-RR liquid cooled model please let me know :D
  6. bait
    bait Active Member
    surely you can drill a hole or 2 into the frame with the one you have and then stick a cuple bolts through with some washers or sumin
    i was actualy going to get on on my sr aswel but im not going to as all of the sidestands on sites are for 50's so i think im going to stick with center stand
