Should I do small end bearing when doing rings?
Discussion in 'The Workshop' started by Mark77, Mar 18, 2013.
  1. Mark77
    Mark77 Member
    My SP180 has done 33000km so I was going to do the rings. Is it easy to do the small end bearing while i'm at it and is it something I should do?
  2. Stig
    Stig Well-Known Member
    EXUP1000
    if they're fairly cheap it'd pay to do it whilst the top end is off. If you're unsure or they're not cheap just check the piston for up and down movement on the conrod (usual to have side to side movement)...if there's any play replace it anyway
    Jonnymarrw00t likes this.
  3. Jonnymarrw00t
    Piaggio Zip 05 plate
    if you do it, make sure you replace the circlips too!
