SHIT PED PLEASE HELP
Discussion in 'The Workshop' started by aprilia123, Mar 28, 2008.
  1. aprilia123
    aprilia123 New Member
    as you can realise i am having loads of problems with my ped cos its fuckin shit! today i was tryin to sort out the electrics etc. i turned the engine on for a bit about 15 min n it cut out because of tick over needing adjusting but normally it starts straight back up and it hasnt started back up since and i havent a clue why. does anyone have any ideas?
  2. MiNoR cOnFuSiOn
    new plug... the idle mix is probably not correct..
  3. Burns
    Burns Active Member
    Aprilia sr50
    as above
  4. chris14
    chris14 New Member
    make sure fuel filter isnt blocked and your getting petrol aswell
  5. alex_1966
    alex_1966 New Member
    yeah had the same problem u had aprilia123 and it turned out 2 be the fuel filter
  6. stephen_h
    stephen_h Member
    can someone tell us where to locate the fuel filter please.
    thanks stephen
  7. alex_1966
    if its the same filter you get on the aerox (im pretty sure it is) , til b on the fuel tank mate ;)
  8. WOLFFY
    WOLFFY New Member
    Run out of petrol?? :p
  9. alex_1966
    haha wollfy i think u just cracked it :rofl:
  10. WOLFFY
    WOLFFY New Member
    Sounds like the most logical answer :rofl:
  11. aprilia123
    got it sorted just needed a new spark plug thanks. and thanks 4 your comments i know i dont know alot abouts peds but i can work out whether its run out of petrol or not seeing as thought i filled it up that day. thanks 4 propper suggestions
  12. alex_1966
    no problem mate ;)
