setup
Discussion in 'Scooter Tuning' started by lay-16, Aug 15, 2007.
  1. lay-16
    lay-16 New Member
    would this set up be good for accelartion
    polini speed control evo kit
    polini speed clutch
    polini clutch springs
    if not what else would be as I don't want 70 kit yet just help me to get a good set up that gives me very good accerlartion then in near future I can just put a 70 kit on to it straight away. thanks for help if i get any :D
  2. lay-16
    lay-16 New Member
    why does no reply to me for ????????????????????? :rtfm:
  3. MiNoR cOnFuSiOn
    because you ask silly questions.. it will give you better acceleration but is pritty pointless with a stock engine. if this is the order you wish to do things in then go for it but its prittymuch pointless without extra power as any gains will be marginal.
  4. lay-16
    lay-16 New Member
    not silly questionm to me though im only 16 and i dont no everythink
  5. MiNoR cOnFuSiOn
    well, it may not be, yet everywhere you read it says fit a 70 kit first as any other parts rely on extra power to work. the manufactor made the best of the power you have, clutch springs will mean it revs higher befor you move. a diff variator will be about the only thing worth fitting with no other parts as they make for a harsher accel curve but this reduces the life of the engine. if you fine tune the transmission without power increase your simply stressing the cyl;inder/crank for verry small gains hence its worthless.. ;)
    cogh cogh buy a 70 first cogh cogh
