a thread for your setup to make it easyer for new members to set up there ped without the same old threads over and over. Only reply if you ped is set up and working fine.Also put in any other bikes you have had in the past and there set up if you can remember it. just copy and paste the list and fill it in no need to go into what variator and clutches or belts your using just keep it as a basic set up for peaple to have a quick look at. only reply with your details use the other sections to ask questions also if your running a open filter but know what jet it used with the air box put that in brackets aswell as it all helps Make/Model - nrg power dt 2007 CC - 50cc (standard barrel) Exhaust - leo vince zx Rollers - 5.5 gram (19x15.5) (standard are 6.5g) Fuel Jet - 62 main (6mm dellorto jets/17.5mm carb) (standard jet was a 53) Air filter - standard air box clutch springs - standard cheers
Piaggio Zip Air Cooled 2005 plate CC - 70cc Polini Sport/Polished exhaust port Exhaust - Leo-Vince TT Rollers - 6.1 Gram Malossi rollers Fuel Jet - 118 6mm Carb - dellorto 17.5mm carb Air filter Polini Short open filter Blue Leo-Vince TT springs (Medium strength) Piaggio Zip Air Cooled 2005 CC - 50cc standard kit with polished exhaust port Exhaust - Leo-Vince TT Rollers - 5.5 gram malossi rollers Fuel Jet - 63 6mm Dellorto Carb - 17.5mm Dellorto Blue Leo Vince TT springs (Medium) Piaggio Zip Air cooled 2005 CC - 50cc standard Exhaust - Yasuni Z Rollers 5 gram malossi rollers Fuel Jet - 67 6mm Dellorto Carb - 17.5mm Dellorto White Malossi Springs (Malossi fly clutch) Peugeot Speedfight 2 Air Cooled 2004 CC - 50cc with Doppler head Exhaust - Leo-Vince Zx Rollers - 7 gram Leo-Vince rollers Fuel Jet - 83 5mm Gutner jet Carb - 13mm Gutner Clutch - Leo-Vince Red Springs
dont think you got the right idea bud the thread was intended for any mods done and how its set up to make it easyer for peaple as all peaple seem to as is what jet do i need or what rollers
'99 Piaggio Zip RST AC Athena HP 70 kit, 0.7mm squish, YSN PHBG 17.5mm carb, Pipercross open filter 98 main jet, Polini straight manifold, Malossi carbon reeds, Leo Vince TT, Technix 'race' adjustable kevlar clutch, Malossi red (heavy) clutch springs, Stage6 'winged' clutch bell, 26kg torsion spring, Polini Kevlar belt, Standard variator, 3x 7.5g 3x 5.5g (alternate) 19x15.5 rollers, Athena free rev CDI. Top racing +25% up gear kit coming soon and converting to 21mm Dellorto as well, also LV ZX to replace TT...
shaame to see this thread disappear Piaggio Zip SP 50 Stage6 sport pro 70 Stage 6 pro rep exhaust Carb, dellorto 17.5 76main jet a7 needle, second clip from top 4g rollers polini green clutch springs (5000rpm) engagement
Very handy thread gives people a starting point at what they should be looking with regards to rollers and jets,they can then have a play around and fine tune their ped to their liking
Got to be fair this deserves a bump,will post my setup when im happy with it but im not atm, it gives the new people a starting point instead of having to buy 20 sets of jets and 10 sets of rollers and many hours chasing their tail. We all know different setups vary We just want a starting point to give us a rough idea what to work around,no point in buying a 46 jet when you need a 96 jet or are going to,this thread is just to save people some money you only have to look at the views on this thread to see how important to people it is
Piaggio Zip SP 50 Stage6 HPC Crank Stage6 MKII Racing 70 Stage6 R1200 Dellorto PHBG 21mm : 92main jet, 45 pilot jet,W7 needle second clip from top. Stage6 open foam air filter Doppler Inner Rotor - ignition timing set as per instructions. Stage6 MKII Torque Control Clutch - Red (stiffest springs) 1 weight on each clutch shoe closest to pivot point. Spring Preload adjusted half way. Stage6 Sport pro variator- 5.25g weights. Stage6 Medium Contra spring. 17stone rider *** On this variator the best full throttle performance was obtained with 5.75g rollers. However it was a dog on part throttle openings and would take a second or 2 to spool up into the powerband when throttle was applied. 5.5g rollers was a slight improvement. 5.25g rollers a slight reduction in full throttle performance as revving past peak power. However this weight keeps it more or less in the powerband at all times for instand pickup and go when you hit the throttle. I believe the only way to improve the transmission at this stage would be with an overrange setup to hold the revs in a much narrower band regardless of throttle position.That way correct full throttle performance can be obtained without sacrificing pickup and initil acceleration. Alternately a less powerful exhaust system with a wider powerband may suit better. **A lighter rider could probably run the same clutch settings only without the added preload on the springs.
Piaggio Zip 02 plate PM Tuning Aluminium X-Tech 70cc top end including head Malossi Multivar 2000 variator with 4.59gr pm tuning rollers. Doppler Full circle crank with C3 high speed bearings 21mm carb with 86 main jet Standard airbox with open type sponge filter Malossi Team exhaust Athena Kevlar belt Malossi 15/37 gear up Quick action throttle Carbon Reed Petals Scooter Assassins adjustable clutch
Gilera DNA 2004 Stage 6 sport pro kit mk2 with ngk br9es Motoforce evo crank full circle Stage 6 bearings Polini variator with 5.0 gram rollers Polini drive belt Carb 17.5 with 88 main jet Standard box with pedmoto filter Doppler inner rotor kit set to 1.5bdtc 360 intake manifold with carbon fibre reeds Stage 6 clutch bell with standard clutch n springs Stage 6 quick action throttle
Piaggio Zip SP stage6 streetrace 70 derestricted standard exhaust 72 main jet 40 pilot jet 7.2g rollers
BRING THIS THREAD BACK TO LIFE Piaggio Zip sp lc Malossi Sport 70cc Stage6 pro rep (derestricted) 72main Original airbox (Derestricted) Malossi double filter 5.5g rollers Green Polini springs ... Found this to work fine no seizures no problems
Tomos A35 70cc cylinder (airsal) High comp head 21mm dellorto Techno bullet pipe. Port match the kit and make a gasket from 0.4mm paper. Good for about 6hp
