setting up my carb
Discussion in 'Scooter Tuning' started by stephenfozzy, Jun 23, 2007.
  1. stephenfozzy
    stephenfozzy Member
    i have a piaggio zip with a tecnigas exhaust and polini high flow air filter, just wondered if ne knows wat the best jet to use wud be and any advice or setting the mixture screws?
  2. Speedy 172
    Speedy 172 Active Member
    what sized jet is standard
    you advised to upjet
    5%-exhaust
    10%-carb
    10%-big bore
    15%-air filter if im not mistaken
    hope this helps
  3. stephenfozzy
    stephenfozzy Member
    well it had a 56 standard but it also had a copper plate restricting the air intake on the carb so i took it out and i got an 80 jet in it and had a fiddle got it running ok it dont bog down but its not as quick as it was at 1 point and checked the spark plug and its running a bit rich was thinking or dropping the needle
  4. tinribs
    tinribs New Member
    is it a 50? 80 sounds a bit big
  5. mhr-rox
    mhr-rox Member
    lol the piz is slow lol jkz opeu gtin gin gd boi get da 20.5mmcab off tom
  6. -Grant-
    -Grant- New Member
    think you should make it so he can understand that properly
  7. stephenfozzy
    stephenfozzy Member
    dont worry m8 hes droopy and no-one understands him lol yeah i will get da 20.5 off tom but gotta get da muni first
