seized :(
Discussion in 'General Scooter Discussion' started by Jamie, Nov 22, 2007.
  1. Jamie
    drove college when i arrived smoke was bellowing out of the exhaust so i assumed top end gasket, came out of class later and started it and water/antifreeze pissed out exhaust, so i left it..went to the gym. came back and it turned over twice on the buttin then the kick start was jammed up. :(
    pretty sure its seized.
    just thought id tell you :emb:
  2. tomo9992
    tomo9992 Member
    RS125
    like i said m8, this happened to me, take the spark plug out and then kick it, if it kicks, its the gasket thats gone so get some new 1's, (have a look at the barrel tho aswell incase theres any scratches on it and if there is use wet and dry to smooth them out) then put it all back together with new gaskets, and u should be away
  3. Haresign
    Haresign New Member
    GPR50 + Peugeot 307
    Should have ran it in properly Jamie!
  4. Jamie
    i did :confused:arc: :wtf:
    seriously i did :(
  5. capri dave
    capri dave Active Member
    AAHH jamie bad luck mate...your gonna have to get the top end off and investigate!!
    Maybe you should of joined the polini posse instead :pimp:
    sorry mate couldnt resist ;)
  6. monty9120
    monty9120 Active Member
    Vespa gts300
    i gather thats why you tried to ring me earlier
    sorry dude was at the nec and left my phone at home
    anyway. i did say there was a high risk failure rate
    your old piston seized and you didnt know why. so why will a 70 kit fix it.
    running in is a little hard on a 70 and you didnt exactly take it steady
    dunno what to say theres a big problem somewhere its not it overheating though as i bled your coolant properly etc
  7. Martin
    Martin New Member
    bad luck jay m8. did you increase oil for the 70??
  8. monty9120
    Vespa gts300
    yep we did
  9. Martin
    Martin New Member
    dont sound good then does it
  10. monty9120
    Vespa gts300
    jamie hoped the 70 kit would solve the bikes problems but now 2 cylinders down on the new engine it doesnt seem so
  11. MiNoR cOnFuSiOn
    gasgets at fault... deffo
    what was that you was saying about how good the 2 extreeme kits were? LOL use proper piggy gasgets.
  12. monty9120
    Vespa gts300
    i never thought a 70 can last long whatever make it is
    obviosusely they do just not that one
  13. Haresign
    Haresign New Member
    GPR50 + Peugeot 307
    my gasket went on mine was well, but only cos it wasn't getting enough oil and melted it when it over heated :p
    Make sure it's getting enough oil otherwise you will be in the same mess I'm in :(
  14. kyle1b1
    haha all the 2extreme crew have fucked bikes because of their kits lol :w00t:
  15. Haresign
    Haresign New Member
    GPR50 + Peugeot 307
    suck a dick! :p
  16. MiNoR cOnFuSiOn
    feel silly about what your sig says yet? LOL... nah im jokin. no oil wont melt a gasget tho. a shit gasget will just melt. piggy/polini gasgets are good..athena aint bad.. malossi aint all that..metal ones should only be used if you know what the hell your doing. but ye. use good gasgets.
    to empty your engine get your barrel off.. pull the bike up on the back wheel and have a friend fill the engine with petrol and then drop it back..now lean forward on the front wheel... then bang loads of oil everywhere and rebuild with fresh gasgets and plug and it should work ok after 20 mins of fucking about keeping it running.. DONT rev it tho
    just let it idle till it dont smoke..
  17. Jamie
    cheers for the replies everyone,, sorry i havent spoken i was asleep :emb:
    but yeh cheers for the help ill have to whip the top end off on saturday or sunday cuz ive got college tomoro/today :p
    am hoping its not to serious.
    ahh well just means that my 172 project will be starting earlier. :cool:
    2 EXTREME FTL(for the lose)
    :nerd:
    stick to well known makes boys..it will be worth it in the end :(
  18. andy_n
    andy_n New Member
    my 2 extreme kit is still going strong :D
    and i was the first one on here to get one
    is everyone whos got one sure they know what theyre doing ?
    i didnt even run mine in for fuk sake
  19. Purplepill
    Purplepill Member
    id still put it down to the owners fitting/running of the kits, rather than the actual kits themselves, if the gaskets were that shocking then surely andys would have gone by now if he's had his longer than both of you. they may not last as long, but jesus they should last longer than a month :w00t:
  20. wobbly_trials
    they bought the kit, clearlythey don't know what they are doing.
