Screeching from gearbox
Discussion in 'The Workshop' started by NRG_JON_92, Jan 22, 2009.
  1. NRG_JON_92
    NRG_JON_92 New Member
    When i start my nrg i get a loud screetching from around the gearbox do you guys think the belt tensioner is faulty or is it just slipping? any ideas will be usefull :pimp:
  2. INO
    INO Member
    Hi, first things you should do is make shore there is nothink in the fan. make shore your drive belts not worn. I had this problem and what i did is,
    1) get some grease
    2) Remove you engine case
    3) Remove the variator pulley
    4) Remove the variator
    5) Take the oil belt off
    6) Take the sharfts out that the belt goes on and grease them up place all back togeather and should be fine mate.
    Reece
  3. jon_w
    jon_w New Member
    does the screech go on forever or is it just for a few seconds...?
  4. NRG_JON_92
    Few seconds untill i get it upto 7-9k rpm
  5. INO
    INO Member
    wel if you read what i said it will resolve the problem
  6. NRG_JON_92
    Well i might not be as bad as what yours was but thansk for the info :pimp:
  7. jimbo180cc
    jimbo180cc New Member
    if he ses its coming from the gearbox why would he want to take he's oil belt off and vrt. makeing more work than anything.
    mate it could be your gearing plate(the seal on that)
  8. jimbo180cc
  9. INO
    INO Member
    YER HE SAID HE THINKS IT COMING FROM THE GEARBOX! SO SHUT UP
  10. NRG_JON_92
    I checked it while i was at work it was just slipping but thanks for the info xD
