scorpion stub two stroke
Discussion in 'Maxiscooter Tuning' started by shiny red, Jan 22, 2008.
  1. shiny red
    shiny red New Member
    got to make a scorpion stub to fit a 125 what is the dia of the exhaust port on a standard barrel so i can match it up?cheers
  2. MiNoR cOnFuSiOn
    26.8 if vertical 27.4 horizontal.. just make it 27 ;)
  3. shiny red
    thanks minor :D
  4. shiny red
    finished heres some pics :D
  5. SMF_12
    SMF_12 New Member
    MMIINNTT!!!
    btw - have you recieved your jet yet?
  6. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    looking good shiney pm with the price if u wanna make another tell me the porice first tho its for a bike i buildign for a mate so gotta tlel him how muc, was gonna order a psn one off ebay for 25 but id rather give u money
  7. nickone
    nickone New Member
    that looks proper good.. one thing tho, the psn are double skinned too stop blowing.. well done tho..
  8. shiny red
    ah did not know that nick one ,whoops need to modify then .
    thanks for that :emb: watch this space :wtf:
  9. tErr0
    If you need any reference pics shiny then drop me a pm. ;)
  10. shiny red
    cheers terro should be ok now i think?
  11. shiny red
    All done......
  12. numanoid1704
    numanoid1704 New Member
    quality job
    another piece of quality kit shiny,looks much better than my one finish wise.cheers
  13. nickone
    nickone New Member
    blimey. now that looks nice...great job... well done..
  14. capri dave
    capri dave Active Member
    shiny..you never fail to astound me :pimp:
  15. shiny red
    :emb: thanks
  16. Daniel172
    Daniel172 Member
    Shiny it show's how much pride you take in you're work. Keep it up fella :D
  17. wobbly_trials
    may have a small challenge for ya shiney, gotta get a spacer made for my yasuni so i can match the stub (round) to the exhaust port (square) on my evo project.
  18. MiNoR cOnFuSiOn
    trace the exhaust port.. then make a 10mm spacer. plenty meat for you to play with, need to shorten the stub and exhaust to suite tho.. makes it a bit weak but its the only way to keep it performing the way it should.. could try moving the mount bracket forward 1cm.. this will accomidate for the difference but
    1. will it fit
    2. will it affect performance in a negative way.. the pipe will effectivly be 1cm longer with the spacer
  19. shiny red
    can make a spacer no trouble,need dia of the hole in the stub and like minor says a tracing of the exhaust port,maybe a pic of the exhaust stub .
    i do not know what the stub looks like ,why not make a new stub which is rectangle to round so not increasing the length of the exhaust , :D
  20. MiNoR cOnFuSiOn
    thought about this myself but still need to shorten the stub/pipe length... spacer is the most commonly used soloution and can be square all the way through.. just needs matching to the stub (angle is slightly diff too..)
