scorp setup on 172
Discussion in 'Maxiscooter Tuning' started by rt08, May 13, 2009.
  1. rt08
    rt08 New Member
    Gilera Runner SP172
    i had a search round on the site but i cant find anything about a good setup for a scorp on a 172 runner? lol
    i bought a scorp for £50 and fitted it, it runs well but my top end has reduced alot :confused:arc:
    my current setup is 172 kit, 180 vari, 3 12g rollers and 3 12.5g rollers, k 'n' n filter and upjetted standard carb
    im thinking heavier rollers will help :confused:cratch: my mate suggested 13.5g?
    looking to get blue malossi springs fitted, new belt and bigger carb so if anyone has any of these let me know ;)
  2. red180172
    red180172 New Member
    172 + custom mk2 vr6
    maybe think bout getting 180 gearing
  3. rt08
    rt08 New Member
    Gilera Runner SP172
    won't i loose acceleration though?
  4. red180172
    u will have enuff power to pull bigger gears,get urself a carb first i spos
  5. MiNoR cOnFuSiOn
    an now back to the question.... 12.25 is your avarage weight.. way too light for a bolt on setup using a scorp and stock carb... might find the pipes full of shitty old oil, they tend to collect alot from the ammount of shit welded inside them. try heavier rollers and upjet a little. should sort it
  6. rt08
    rt08 New Member
    Gilera Runner SP172
    cheers minor ill check tomorrow :D
    is there a way to clean the inside of the pipe out?
  7. MiNoR cOnFuSiOn
    sure is.... find a suitable bottle cap to tape on the stub end of the pipe (raid the birds deoderant, there cans are smaller) bung some white spoirit in it, seal the other end wiht a cork. leave it in a few diff positions then shake it a bit, then leave it, then empty out.. strip the end can out (obviously remove befor the first step) and replace the wadding... get it as tight as you can.. literally.. wear gloves. tighter you get it the better it works. enjoy
  8. rt08
    rt08 New Member
    Gilera Runner SP172
    cheers mate :tup: i'll have a go tomorrow if i've got the time
  9. rt08
    rt08 New Member
    Gilera Runner SP172
    well i cleaned the exhaust out with white spirit yesterday like minor said
    then today i fitted some 13.5g rollers
    now it power wheelies at half throttle :w00t:
    top speed is still around the same as before
  10. TyphoonLagoon
    TyphoonLagoon New Member
    told u 13.5gs with a scorp ;) wheelies like fuck
