scooter bogs down
Discussion in 'General Scooter Discussion' started by richy1985, Oct 12, 2013.
  1. richy1985
    richy1985 Member
    I am currently riding a piaggio fly 50 4t and when its cold and twist throttle it bogs down u ave rev it a couple of times to get it going.. any info how to fix would be great thanks :)
  2. Stevep
    Give it about 1 minute for the auto choke to switch off after starting, then pull away.
    If that doesn't work then change the auto choke for a new one
    richy1985 likes this.
  3. richy1985
    richy1985 Member
    done that mate and still the same will buy a new 1 and see wot happens cheers mate
  4. Stevep
    does it run fine/accelerate ok when its warmed up?
  5. richy1985
    richy1985 Member
    yh all fine then
  6. Stevep
    In that case, go for a choke change. That's the cold start.
  7. richy1985
    richy1985 Member
    will order 1 I can hear it kick in when I start it up. but I think what is happing is it mite not be going back in causing it to be over fueling ?
  8. Stevep
    When it doesn't shut off properly, it causes the engine to run rich even when its warmed up. Could just be sticking on longer than needs be but it will gradually get worse. And they can't be opened and cleaned, just replaced. Not expensive to replace, but it is the first place i'd start with those symptoms.
  9. richy1985
    richy1985 Member
    will get 1 oreder of ebay cheers matey :)
  10. richy1985
    richy1985 Member
    Got 1 ordered so hope it fixes it lol will post when fitted it
  11. richy1985
    richy1985 Member
    No mate only a automatic choke
  12. richy1985
    richy1985 Member
    Fitted part today seems a lot better fingers crossed it woz the choke cheers people for advice :)
