Sat Nav Units......
Discussion in 'The Workshop' started by cranky, Sep 18, 2008.
  1. cranky
    cranky New Member
    Has anyone fitted a Tom Tom Rider sat nav unit to a Gilly Runner ?
    If so, how and where is it positioned on your scooter......?
  2. typh70
    typh70 New Member
    i used a normal satnav on a nice day and put the suction pad on the lense over the speedo...
    only used it once that way but it seemed to work
  3. alexsr70
    alexsr70 New Member
    well wire the power cable up to the clock panel
    then take the adjustable arm bit off the bracket, then get 2 L brackets and it fits nicely below the clocks facing up perfect
    went on my renthals nicely tho ;)
  4. MiNoR cOnFuSiOn
    best place on a runner is between your knees just behind the clocks on the middle pannel... many fitted here.
    i jus use earphones when riding wiht a satnav.. who the fuck needs a map aswell as the annoying voice? :confused:
  5. Kizza
    Kizza New Member
    Cranky pal, Are you from grimey n ride motocross?
