rusted seized screws
Discussion in 'The Workshop' started by Callum Coles, Sep 9, 2012.
  1. Callum Coles
    Callum Coles 2003 Piaggio Zip Sp
    2003 Piaggio zip sp
    my question is how do i remove a rusted/siezed bolt on my bike it the ones that screw the cover over the cooling fan and stator i tried removing one and the head snapped off it was soked in wd40 for about 10 mins and still didnt work in the end i snapped it by accident theres still 2 left is there anyway to remove the snapped screw and the rest without snapping them ?
    also how do i remove the rear wheel tried everything just wont budge lol ?
  2. Chubz
    Chubz Well-Known Member
    70cc Aerox 04'
    Could try mole grips ?
    Or try cutting into the bolt so it can be turned with a flatheaded screwdriver...if you know what i mean
  3. Stig
    Stig Well-Known Member
    EXUP1000
    try an impact driver after they've been soaked overnight with releasing oil. If they then snap they'll need drilling out. If you have access to some heat, try warming the surrounding casing before trying to move them. The heat expands the surrounding metal and the shock of the impact driver then breaks the bond between the ali and the steel screw. Once you've got them out, replace the new ones with a smear of copperslip
  4. Callum Coles
    2003 Piaggio zip sp
    Okay thanks :p
