Running without tranny case
Discussion in 'Scooter Tuning' started by rezzin, Feb 3, 2008.
  1. rezzin
    rezzin Member
    Can i go for a quick blat up the road with my Variator Casing kept off just while i try different roller weights? Gets annoying when i keep having to put on the casing and take it back off again etc. Literally a 30 second blat it would be. Thoughts?
  2. MiNoR cOnFuSiOn
    engine is likely to snap.. and how you gonna start it?
    i put my finger through the starter pinion/front pulley starting a bike without the cover on..
  3. rezzin
    rezzin Member
    fuck. erm electric start? ill just whack it back on with a few bolts then i guess. thanks anyway mate. so would you say 5.7 is a good weight to order if its pretty much perfect right now? because ill have a set of 5s a set of 6.5s and a set of 5.7s so i can have a little try with each set (no mixing though this time) thanks
