running pre mix!
Discussion in 'General Tuning' started by TyphRider, May 10, 2013.
  1. TyphRider
    TyphRider Active Member
    Piaggio typhoon 70cc
    I want to run premix on my typhoon would i need a new carb that doesnt have the oil feed, and how would i go about removing the splitter from the throttle cable, could i just run the throttle straight through? thanks
  2. MARSH
    Just block oil feed pipe into carb, take the oil pump cable out the splitter.
  3. TyphRider
    thanks mate :)
  4. Scooter-Noob
    Scooter-Noob God among idiots
    AEROX in box's :-D
    no real need to change anything with the cable. and yer as said block the oil inlet on the carb and your golden
    ALSO DON'T FORGET YOU NEED TO UP YOUR JETTING
  5. MiNoR cOnFuSiOn
    you really do, as if you dont remove it it jams your throttle... dont give out bad advice, its written everywhere
