hi guys am new to this site so go a little easy on me :lol: . im wantin to run ma speedfight 2 without the battery but i cnt figure out how to? its the aci100 imob version. i also want to get rid ov this imob and run a standard cdi similar to a 4 stroke pitbike 1. iv found this site http://elystar.ardane.com/nonchipkey-en.htm. which gives a step by step guide to convert the aci100 to a standard cdi. if any 1 can help with the 2 probs iv got ill be very graitful. please dont ask y im doin it :L its jst something iv alus wanted to do since i bought the ped in 2007 new.
no, just no... they make an immobiliser free speedfight cdi. buy one from scooterattack or somthing (check the links section) as for running it wiht no battery? WHY? you will just burn through rec's and eventually when you go for an mot it will fail as the indi's wont flash properly and lights will be too dim (all tested at idle) my typh is battery free.. but itsa only because it had an mot and i needed the battery.. going back on (as is the key for the ignition swithc as its just an on off switch atm) again, why would you want to ditch the batteryy?
