Running issues
Discussion in 'The Workshop' started by qdg8511, Aug 28, 2016.
  1. qdg8511
    qdg8511 New Member
    Aprilia SL1000 Falco
    Got a 2003 Piaggio Skipper 125. Bought it as a job lot few years ago. New battery and fresh fuel and started without much resistance. Unfortunately work and other projects got in the way and the scooter took a back seat. Finally found time to get at it again, starts, ticks over but won't rev. Have put new fuel tap in it thinking diaphram might have perished over time but still the same. Any advise on what might be wrong.
  2. qdg8511
    qdg8511 New Member
    Carb sonic cleaned and fresh petrol in it. It will tick over but as soon as you try to rev it it cuts out.
  3. qdg8511
    qdg8511 New Member
    Not sure, i thought it was a diaphram system
  4. dazz
    dazz Member
    Is the spark blue or yellow?
  5. qdg8511
    qdg8511 New Member
    Spark is good, new fuel tap fitted. Will check diaphram in carb, only thing i've not checked.
  6. dazz
    dazz Member
    I presume if its got a diaphram in the carb its a 4t ?
  7. qdg8511
    qdg8511 New Member
  8. dazz
    dazz Member
    Check compression.
