Running issues..... please help
Discussion in 'The Workshop' started by rems, Jan 13, 2018.
  1. rems
    rems 2000 pac man zip
    hi all
    So my bike has been running spot on until the beginning of the week and now it won't run atal
    My set up is
    70cc pro sport kit
    Standard crank
    Motoforce 19mm carb 94 main jet
    Malossi cone filter that has the cover
    6.75 rollers
    Stage6 exhaust
    Stage6 inlet manifold
    Motoforce coil pack
    Running premix
    All was fine until Monday night riding home it had a little cough and splutter but didn't think anything of it as still ran fine
    Next day on the way to work warmed up and idled fine got down the road at full throttle and spluttered than cut out, would start up fine but as soon as I went to ride it past 1/4 throttle about 10mph it would splutter and cut out.
    Pushed it to work replace the fuel tap as it was original and needed doing, stripped carb and cleaned it
    Checked piston and cylinder no visible score marks
    Put it back together and started fine let it was up and problem is still present
    I went down jets in stages to 86 and didn't really make that much of a difference
    Only thing I have done since it was running perfect was top fuel up and used different 2 stroke oil than I usually do (usually use castrol but petrol station only had motal, or similar from texaco)
    I'm now lost at what my problem could be?
  2. Stevep
    Reeds, manifold leak, air filter (try with it off)(in dry weather)
    Do a compression test.
  3. rems
    I sprayed around the inlet with brake cleaner and there was no change in running to suggest a leak
    Reeds look ok with no bends or damage in them, I do have a spare set that I will try
    I done a compression test and it was 7.3 bar about 106psi
    I don't know what the compression should be
    Checked wiring and found no visible breaks or corrosion
    Going to get new cylinder gaskets
