Running an AC NRG engine without the loom?
Discussion in 'The Workshop' started by KH3M, May 9, 2012.
  1. KH3M
    KH3M Member
    NRG MC3 Jordan
    I've got loads of spares left over from my Jordan project, and I've been bored as hell recently so I decided to undertake a little project.
    I've basically got more than a whole bikes worth of spares so I built myself another one. It's just a scrapper, but i want something to mess about on.
    Anyway, because the bike is basically just a frame I've not used the loom. How can I get the engine going without it attached? Because the auto choke is constantly off and I don't have a manual one and I'm pretty sure the ignition wires need to be fiddled with.
    Cheers
  2. J4CK
    J4CK Member
    Piaggio NRG 172
    There should be some wires on your engine that plug in the CDI plug them into and as for choke not too sure id just get a manual :)
  3. KH3M
    KH3M Member
    NRG MC3 Jordan
    Sorry, I couldn't understand that first bit.
    I have a Haynes manual, but I can't imagine it will be of any use?
    I have the choke wires, the ignition wires and another one which I'm not sure about. How can I bypass plugging these into the loom? I've checked for a spark, and there is one (because it gave me a shock)
    Someone help me out? :)
  4. Anton Kash
    Anton Kash Member
    Typh
    you need to plug the wires from stator to cdi/coil and have a earth itll work.
  5. J4CK
    J4CK Member
    Piaggio NRG 172
    And as for the choke you would have to look at nrg mc3 wiring diagram and see how its wired up but if i was you id use manual:)
  6. KH3M
    KH3M Member
    NRG MC3 Jordan
    got the engine started, and after got electroctued by ripping the spark plug out with my hand.. :confused:
    it revs really high when you start it, the clamp i put on the brake fell off and it nearly him my brother in the face o_O
    i've fiddled about with the idle and mixture screws but nothnig really helps.. i'm also running it premix, on fully synthetic - so no seperate oil tank. It just revs really high, enough pull itself away easily. it's all standard, apart from the leovince tt with the huge hole in it.. i know that's not the issue, i'm putting down to the carb..
  7. Aaron Hastings
    Aaron Hastings 125 KiLLa!
    Mk1 piaggio zip sp.
    check the throttle cable is in the carb properly, might not have slid all the way down, done this on my speedfight once.. got on it started it up and nearly rode through my front door lol
