Runner SP 50 carb issues
Discussion in 'The Workshop' started by SectorOMEGA, Jun 22, 2015.
  1. SectorOMEGA
    SectorOMEGA New Member
    Hello All. Recently bought a runner sp 50 all stock and derestricted. It was running nice and I want to tune it up a little. So bought a 70cc Polini and Stage 6 pro replica from a friend who was breaking it for parts. The carb is 17.5, with jets: idle:32 and main:53. When I have fitted the kit and the exhaust it was running quite nice but slow. At the start it goes quite good, then reaches 40(7k rpms) stays there for a minute, and after that it starts to gain speed again. By advice of a friend I should change the main jet at around 85 to 90. Bought up a kit of jets from 75 to 98. And there we go with the problems. Its cutting bogging not going at all, even hard to start. Carb has been cleaned 4 times and it's spotless. Even when I return the 53m jet its the same. Needle is 3 places up from low point. Nothing is helping and I'm struggling with this a week from now. Derestricted from everywhere. Any advise would be great and really appreciated. Thank you in advance
  2. ramo
    ramo GoldMember
    Even the 75 might be too big. The rollers will need changing too
  3. Stevep
    Do a compression test. Reading should be upwards of 100psi.
  4. gilly_runner
    gilly_runner Member
    Gilera runner
    75 will deffo be too big i had a 70 in mine with a slightly higher spec and it ran like a dream.
  5. SectorOMEGA
    Excellent Gonna try with 72 as this is the smallest one I have at the moment. Now its with rollers 5.2gr and there is slight better but still have those cutting sounds. Gonna try I post again. Thank you very much :)
  6. SectorOMEGA
    Niceeee! 75 jet makes it run awesome. But there is another problem. When I drive it for a little around 6/7km it cuts out. When I try to start it again it doesn't. After one cigarette time I was able to start it, but it was bogging. Left for a little while and there we go again awesome running. Next 6/7 km and again the same. Any ideas?
