RUNNER GEARBOX!!
Discussion in 'The Workshop' started by rider4life, Mar 31, 2008.
  1. rider4life
    rider4life New Member
    bought a set of malossi gears like new already pressed onto the shafts. i didnt know how they went so i copied my standard gearbox used the right shims in the right places but when i turn the imput shaft it sounds a bit rough. could it be because theres no oil on them at all as i cleaned the gears and there dry (no oil) .
  2. wobbly_trials
    the streight cut gears are usually a bit loader than the stock ones and the lack of oil will give a kind of grinding noise, get some oil in and see what it's like
  3. rider4life
    cheers brilliant mate. whats the best oil to use so i can get some tomorrow.
  4. rezzin
    rezzin Member
    wd40. :rofl: :bird:
  5. rider4life
    looooooooooooooool
  6. wobbly_trials
    close except your numbers and letters are wrong :p (EP90)
  7. monty9120
    monty9120 Active Member
    Vespa gts300
    80w90 gear oil anywere does it. im not suprised there rough with no oil :w00t:
