runner fx125 throttle cable
Discussion in 'The Workshop' started by stephen_h, Mar 4, 2008.
  1. stephen_h
    stephen_h Member
    ive bought a runner fx 125 and i have finally got it running but the throttle cable is slack can anyone tell me if and how i can tighten it or do i need to buy a new one
    thanks stephen
  2. Jamie
    there is an adjuster identical the the oil adjuster but its on the top of the carb where it goes into thr carb, just scre the adjuster out until you loosee the slack
  3. stephen_h
    stephen_h Member
    nice one thanks jamie i will have a look at it tonight
  4. numanoid1704
    numanoid1704 New Member
    cable
    remember to leave a little bit of slack though :D
  5. StEvO
    StEvO Active Member
    theres also the handlebar side adjuster if that doesnt work
  6. stephen_h
    stephen_h Member
    thanks ive got the cable sorted now but i have now been banned from riding it anymore till april by my dad
    however when i was out riding tonight when i full throttled it overtaking a car the oil light came on but i had just filled it up but when i let off the light went out.
    can anyone tell me how to solve this problem now please
    thanks again stephen
  7. MiNoR cOnFuSiOn
    ether the wiring on the oil tank sender, thas the plug in the oil tank (usually the lights flicker if its this) or the sender is on its way out/busted
  8. stephen_h
    stephen_h Member
    thanks for that minor il have a look at it tomorrow
  9. monty9120
    monty9120 Active Member
    Vespa gts300
    have you got a battery
  10. stephen_h
    stephen_h Member
    ye i have a battery, why?
  11. monty9120
    Vespa gts300
    the oil light stays on when your batterys dead or if you havent got one
  12. stephen_h
    stephen_h Member
    thanks monty i think you have just solved my problem some times the electric start works and others it dont so it looks like i need a new battery
    thanks stephen
