Runner down pipe help
Discussion in 'The Workshop' started by sr 125 01, Dec 7, 2013.
  1. sr 125 01
    sr 125 01 Member
    Ok bought a over size down pipe sis
    So bolted it on to the bore
    But don't line up with exhaust
    Have 3 runner down pipes all look the same ?????
    [​IMG][​IMG][​IMG]
  2. creamsodauk
    creamsodauk Ped Ped!!
    Runner 125 SP
    have you loosened the pipe up a fair amount??
    when i fitted my down pipe (stock) i had to unbolt the pipes main bolts and lift and tilt the pipe to the right angle then bolt everything up so nothing was resting or had any weight on it.
  3. sr 125 01
    sr 125 01 Member
    U fist bolted to the bore but if I bolted the exhaust on it didn't line up with the bracket holes
    So then tryed bolted the down pipe and exhaust together but if I bolted to the bracket it was 50mm away from the bore ???
    They look the same
  4. ramo
    ramo GoldMember
    Put the downpipe on loosely and then the same for the silencer then attach the two together and tighten all the 3 sets of bolts up like gradually till you get a good fit
    kierran likes this.
  5. sr 125 01
    sr 125 01 Member
    Thanks bro did the way u said
    Job done
    Thanks ramo
