Has anyone on this forum done this conversion? (yes i've used the search) I'm wondering wether to do it but i dont know if i should as i think the 125 frame is bigger/taller etc, which would be better for me or is it? :wtf:
its pretty simple, im sure you know how to do it, but like you said the 125 brakes and suspension are dif, so you might want to upgrade them as well
Basically to make the conversion straightforward you need a 125/180 wireing loom!! Then when youve swopped the looms over...the 125 engine just plugs into the loom with no messy spliceing of wires!!..allso your lights/electrics will be upgraded to keep the ped legal...(mopeds and scooters are covered by different lighting regulations) its a fairly simple conversion...3 or 4mm needs to be ground off the the engine mounts to fit the 125 engine in
