Runner 50 petrol issues
Discussion in 'General Scooter Discussion' started by Noddy, Nov 7, 2017.
  1. Noddy
    Noddy New Member
    Hi got my self a gilera runner 50 lc project
    Am having issues with getting vac for the petrol the tap works because when I suck on the pipe it pushes petrol threw
    So under investigation I realised I wasn't getting suction from the inlet so removed the inlet and reeds messed about with them put them back in notice the inlet had cracks in but didn't look to be Al the way threw turned the bike over a few times and it worked was feeding petrol to the carb
    But now for some reason after messing with the carb and petrol pipe it won't work again
    Am thinking it's not seals as it worked for 5 mins
    Any help or advice plz
  2. Noddy
    Noddy New Member
    Any body help plz
  3. scubabiker
    Compression? Crank seals? The inlet gasket? Split vacuum hose?
  4. Noddy
    Noddy New Member
    It's not the hoses am hoping it's the inlet as It worked when messed with it then stopped ordered a new inlet and Reed block just have to wait and see when it arrives
    Thanks for the response
    scubabiker likes this.
  5. scubabiker
    Yeah, try that then look at compression if it still doesn't start
