Runner 180 very hard to cold start
Discussion in 'The Workshop' started by Dave1211, Dec 14, 2017.
  1. Dave1211
    Dave1211 New Member
    hi my standard Gilera 180 2t was running fine in summer but now it’s cold it’s a nightmare to start
    It starts for a second or two then cuts out I’ve changed the auto choke for a manual as I thought it would be that but it’s made no difference once it’s running it runs like a dream and starts first time once warmed up the plug is only 500 miles old and looks clean when removed please can anyone help it sort of seems like fuel starvation but then I guess it would happen all the time thanks appreciate any reply’s
  2. MARSH
    Battery condition? Take the rear bulb out and try that one time and tell me how it goes !
  3. Dave1211
    Dave1211 New Member
    The battery seems fine I’ve got it plugged into a trickle charger and it turns over perfectly it does seem easier to kickstart but it’s defiantly not flat would the battery cause this issue ? As I say once warm it’s fine it’s only when it’s cold ?
  4. Dave1211
    Dave1211 New Member
    It’s doing my head in but I will try that tomorrow and get back to you
  5. Dave1211
    Dave1211 New Member
    Thanks
  6. Dave1211
    Dave1211 New Member
    Hi tried taking bulb out made no difference any other ideas
  7. Stevep
    Raise the carb slide needle by moving the circlip down one slot
  8. MARSH
    The rear bulb trick was to not use 21w power as it drains the battery, as it hasn't altered anything I'll have another think on it!
  9. Dave1211
    Dave1211 New Member
    It’s a dellorto phobia 20.5 can you explain in a bit more detail how I find this needle and what exactly to do
    Thank you
  10. Dave1211
    Dave1211 New Member
    Phvb sorry
  11. MARSH
    Unscrew the black top off the carb, lift it out and you'll see a brass needle, squeeze the spring up to release needle. You'll see a tiny "E" clip at the top and notches, with the point down move the E clip down one notch, this will richen the mixture.
    Reed petals worn?
  12. Dave1211
    Dave1211 New Member
    Hi marsh I did that moved the clip down a notch but it didn’t seem to make any difference it started for a second or 2and cuts
    The clip was one notch down from the top so now it’s on the third notch down is that about right ? I’ve got a brand new Ngk br9eix that I’m going to gap and fit tomorrow so il let you know how it goes and thanks for ur help pls let me know about needle position
  13. MARSH
    A ngk br9es will be ok, have you checked the reed petals?
  14. Dave1211
    Dave1211 New Member
    I’ve only got the iridium plug as was told they last longer will that Ben ok
    I’m sorry not sure what Reed petals are please can you explain
    Thanks
  15. Stevep
    I've just had a thought
    This is a 180 2 stroke
    It needs very good compression to start properly, around 150psi if i remember rightly.
    Get a compression tester, or borrow one if you, and get the compression reading
    These bikes will start and run with less, but grudgingly.
  16. MARSH
    Take carb/inlet manifold off and you'll see the reed block, small thin sheet either metal or carbon, check for gaps or fraid edges, It's basically a one way valve.
  17. Dave1211
    Dave1211 New Member
    Guys I’ve sorted it :)
    New plug br9eix starts on the button
    The plug in there was a br8es and obviously that was the cause
    Thanks for all ur help it’s been appreciated
    One thing though is why did the br8es work in summer but not winter
