Runner 180 Flywheel puller
Discussion in 'The Workshop' started by US Runner180, Nov 24, 2007.
  1. US Runner180
    US Runner180 New Member
    Good day,anyone know where I can get the correct puller for Gilera Runner 180 flywheel? I have a 27mm puller and it is too small. Thank You.
  2. US Runner180
    I think I found the correct puller from the scooter center it is a 28mm-1mm.
  3. MiNoR cOnFuSiOn
    can make one fairly easily with 2 bolts a drill and a tapping set..
  4. US Runner180
    Thanks for the advice,I believe I'll try that when I get home. I have not had a chance to look at the flywheel very closely yet. Just know that the puller I have was too small. Hey "Minor" do you have a port map that I can port to? Thank You!
  5. MiNoR cOnFuSiOn
    i do but i dont really share them tbh.. all ill say is 1mm raise on the exhaust. square off the top and point the top edges out by 2-3mm.. should be a nice lil boost ;)you want the middle of the port open around .4mm at the middle of the exhaust when the edges are on point.
    i learnt the expensive way so im not gonna give away thousends of quid in development :D
