Hi I have a runner 180 2t Riding to work hear a loud squeaking noise so I pulled over turned the bike off turned on again turned the bike then allow bang Got the bike home took the engine case off as I did the area it's a starter motor all fell out The crank has snapped off So then I took off the flywheel cover to see if it was seized but the piston Is moving thank god Any one no y this would happen ????? Just. Worried if of got another crank it would happen again
That's what they do, I've known 125's to brake off! It's the weight of variator on the crank that's the cause.Just replace the crank/mains/seals/water pump.
ouch.good job you wasn't moving when that let go.doppler cranks are good for 18000rpm but dunno if they would stop that happening can/do vatiators need balancing?honestly never seen a crank snap outwards of the mains.not heard anyone have issues with malossi either.
have a look on pedparts and donotlink pedstop.S6 looks a nice bit of kit..motorforce..nuraku...stay away from Standard ones if you wanna cane it and not have to think about it letting go. £100-125 for 50cc dunno for a 125/172 converted.
mmM.typed donotlink pedstop and it got changed to donotlink but when i went to edit...it showed adrenaline. Are we being censored??
